    English Help
    9 פוסטים 5 כותבים 740 צפיות 4 עוקבים
    • M מנותק
      mf
      Hi, I live in america so i don't know hebrew well, I hope someone can help me
      I'm trying to set up a special extension.
      My system has this option:
      'press 1 to leave a message for the public, press 2 to hear all messages left to the public'
      When the caller records a message, the message can only be posted for the public AFTER it has been verified by the manager.
      How do I set a verification step? What are all the hagdarot I need?
      thank you
      D תגובה 1 תגובה אחרונה תגובה ציטוט 0
      • D מנותק
        dudu @mf
        @mf
        What kind of system you have? ivr2 or another?
        • B מנותק
          brochabar @dudu
          @dudu אמר בEnglish Help:
          @mf
          Why not? If he asks what the definitions of it are
          Turns out it's ivr2
            איש יהודי טוב
            נערך לאחרונה על ידי איש יהודי טוב
            @mf
            Make a recording extension without the recording moving to
            extension 2, but the recording will remain in extension 1 (which is basically a default setting) and then on the website / cell phone you will hear the message in extension 1 and if you want it to be heard in extension 2 just transfer the message
            Hope I helped and that everything is written in an understandable way
              שאול @איש יהודי טוב
              @איש-יהודי-טוב אמר בEnglish Help:
              @mf
              or, to make it easier, open a new extension (lets say 3) and setup to move all recodings from ext 1 to there
              than, on extension 3 setup a key to move the playfile-(recording) to ext 2
              • M מנותק
                mf
                thank you! that was very helpful. I will do that
                1 thing i am confused though - how do i do this:
                "on extension 3 setup a key to move the playfile-(recording) to ext 2"
                  שאול @mf
                  @mf אמר בEnglish Help:
                  👇 button here תגובה first thing, if you respond to me please use the
                  now to the setings, in ext 3 enter the following codes
                  control_playX=file_move
                  file_move_open=yes
                  playfile_control_play_file_move=2
                  all settings taken from here
                  • M מנותק
                    mf @שאול
                    @שאול-ני-ו
                    Thank you. When I enter option 3, what do i press (while the file is playing) to change its location
                    this is so helpful - thank you THANK YOU!
                      שאול @mf
                      @mf
                      you tagged someone else5abf2577-dd9f-4ea6-a194-7a9113e7a3a1-image.png so i didnt see your post
                      the butten you are setup here
